98 f150 surges 5.4 motor
rrruschman
07-20-2004, 07:05 PM
my 98 f150 surges between 30 and 50 mph. change the plugs i put the bosch +4 in and checked the u joints drove it long distance gets 15miles to the gallon . the check engine light does not come on am trying to figure this problem out without pulling the plugs backout for this is along process any help would be great thanks
landyacht
07-21-2004, 11:20 AM
Possibly something with the fuel lines or the fuel pump itself?
macktoschool
07-22-2004, 03:41 PM
check the OBDII for a transmission code. Buddy of mine had the same issue and it was a transmission
Car Pal
07-22-2004, 07:39 PM
if it has separate coils for each plug it could be a coil.sometime coolant drips on the #4 from the bypass hose on the intake.
Paul Masley
07-23-2004, 09:09 PM
The surge may be caused by the torque converter. Ford has had quite a few problems with this. Flush the fluid twice and see if it goes away.
DO NOT USE A POWER FLUSH ON A FORD TRANNY!
97chevyman
07-29-2004, 08:19 PM
sounds like a C.O.P. ( coil over plug ) problem to me. Might want to change your o2 sensors too. Usually around 80K to 100K they are junk any how, they might be the culprit.
