Reprograming PCMJerry Baumgarner 01-30-2002, 01:10 AM Does anyone know someone that reprograms the PCM for the LS-1, other than Super Chips or Hypertech? They are expensive and they are probable good for one that wants a program just like the one that every one else has that has a car like his or hers, but I don't think that they go far enough to complete the job. Sure, they address the main stuff to some degree, ( I think that they could do a lot more) but the little things, like disabling the air pump for one example, they don't address. You say what is problem by not doing several little things? A number of over looked little things can add up to a bit of lost performance. So I ask again, Does anyone know someone that reprograms the PCM for the LS-1 and does a great job for a fair price? Blackbird01 01-30-2002, 07:54 AM Cheapest I've seen is $450. You can have your car dyno programmed/tuned for $500. Both services are offered by Speed Inc. here in Schaumburg, IL. Ed Wright at FastChips is probably your best bet though. You could also look into buying LS1 Edit. Although, you sorta need to know exactly what you're doing with that kinda program. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
