S10 Blazer throttle sticking
Google
Web AF
chevy8500
07-15-2004, 10:37 PM
When I initially step on the throttle, it sticks and then will let loose and the blazer will drive like normal. The throttle has just begun to stick within the last few months. Is there a grease zert or some other way of lubricating the throttle cable to free up its stickyness?
Thanks.
pressman20
07-16-2004, 07:41 PM
Go buy a can of throttle body cleaner, the butterfly is probably gummed up with carbon. If that doesn't work, you will have to replace the throttle cable.
Hope this helps you.
philsblazer
08-09-2004, 01:13 PM
Mine did the same thing - There is an adjustment screw just above the area where the throttle cable connects to the throttle body that acts as a stop for the throttle body butterfly. What has happened is the butterfly is closing too hard into the throat of the throttle body and binding a bit, adjust the set screw to just keep it from 'seating' into the throat.
jefcar
08-16-2004, 12:17 PM
mine was the butterfly sticking on the throttle body, cleaner and fine emery cloth is what i had to do, cleaner would not do it alone.
Google
Web AF
