Any clues to fix instrument lights wanted.
jie
07-14-2004, 03:11 PM
93 J30
When I got it two month ago, all the lights work.
4 weeks ago I turned on the head light. All out side lights work, but no instrument light comes on, all of the buttons are dark. A/C and radio work, but no light too.
All the fuses are ok.
I want to fix it by myself. Any body has experience? Any help appreciated. Thanks.
ashleywat
07-23-2004, 02:25 PM
try tapping on the roller that allows you to adjust the dash and radio lights, I have had my 94J for about 8 yrs and every once in a while I have the same problem, but tapping on the roller or around it always seem to work. Im sure the connection underneath is loose, hope it helps.
jie
07-23-2004, 05:20 PM
Thanks ashleywat. I will try.
Underground_Killah
07-24-2004, 01:23 AM
yea it happens sometimes.. it's a loose wire or something, but i wouldn't fool with it.. just tap it or roll the dimmer switch back and forth a few times and press up on it pretty hard.. usually they will pop right back on.
jie
07-25-2004, 07:34 AM
Thanks ashleywat and Underground_Killah for kindness instrutions.
I tried it again and agein, but it doesn't work. What should I do next?
jie
07-31-2004, 12:56 PM
yesteday evening, it was raining. i turned on the head light. all the dash lgihts come on at the same time. it was fixed by itself!!!???. #$@&*!`~
Thanks every body.
