ac problem
gah03
07-12-2004, 11:21 PM
ok so here is my problem with my 95 GC, my ac clutch dosen't always like to cycle. I think it is the wiring harness/connector going into the cycling switch, due to the fact that usually if I pinch the wires leading into the connector for a short time it will start cycling again(though this has become more difficult as of late).
Is this my problem? And if it is where can I get the connector and how difficult is it to replace?
also is there a temporary fix til I can get the connector
Thanks
Greg
Nautica1728
07-16-2004, 02:08 PM
I have the same year jeep and the same problem. Sometimes it grabs and it blows out cold and sometimes it doesnt and then its warm. I tried to re-charge it and that helped it blow out colder but it still grabs on and off. Sometimes when I use it i have no problems and sometimes its fine. I do find when I put it on low it stays on longer. But i am not sure as what needs to be fixed
