Power Windows/Locks Fuse Location
mconboy
07-12-2004, 07:06 PM
Hi. I own a '95 Camry LE. Last night my power windows and locks all quit working simultaneously. My suspicion is that there is a blown fuse. As to the underlying problem of why the fuse blew (if it did) I have no idea, but right now I want a quick fix because my windows are stuck down and it's raining hard. :( (yes, I put some plastic over them, but who knows how long it will last??)
At any rate, I looked in the owner's manual to find the type of fuse necessary (30V Female "type C") and bought a replacement. My problem is locating the fuse. The schematic shows the fuse in the instrument panel fuse box, but where the diagram says it should be, there is a blue box labeled (I think) "Relay Integration". I can't see any way of opening this box, so I'm stumped as to how to replace the fuse. If anyone knows how to open this box, or where the fuse may be if it's NOT in this box...please let me know. Thank you.
- Michael
mconboy
07-12-2004, 07:11 PM
Just to clarify, none of the power windows and none of the power locks work from any switch. They all went dead at the same time. I don't know if it's a blown fuse, so any advice at all would be very helpful.
ishop4less
07-12-2004, 09:12 PM
Go check fuse junction box on the driver side,it is located inside/behind the coin box (where you put the coin). Take the coin box off you will see bunch of fuse over there and check for the power fuse 30Amps.
mconboy
07-13-2004, 02:52 PM
I am looking on the instrument panel fuse block (the one inside the coin box; this is around where the owner's manual indicates that the fuse for the power windows/locks should be) but I have not been able to find a pink 30A fuse.
On the opposite side of the fuse block inside the instrument panel, I found three gray blocks. On them they say 30A, but they look nothing like the 30A pink fuse I bought. Are these fuses or relays or something different? It looks like this is what the owners manual is referring to for the power window fuse.
In the owners manual, these blocks correspond to 1) rear defogger 2) power windows, power locks, power moonroof 3) starting system (I think, not sure what this is). They are all labeled identially (30A). They are gray blocks about 1 inch square with four prongs on the back that plug into the back of the fuse box.
I decided to experiment by swapping the block for the rear defogger (which works) but this did not fix anything. So, I'm still kind of lost. If there is a pink fuse for the windows, I have not found it yet, but I will keep looking. Please post if there are any further suggestions.
- Michael
