Window Stuckgudgrll 07-12-2004, 03:07 PM Hi Everyone, I need help, my window on my 95 Honda Accord, 4 door is stuck. Actually one in the back wont go up or down, drivers side will go down not up and its a big mess. One guy said it was the motor, any ideas or suggestions. joeval 07-12-2004, 03:13 PM Before you change motors, check the fuses then check if there's voltage at the switch with a voltmeter or test light. If there is voltage going in, check if there is voltage going out when you press the switch. For this, you need to take the switch out. (depending on your door, you may have to take the panel off to get to the switch. If there is no current going in, it might be a fuse or a broken wire. If there is no current going out, the switch is busted or just dirty and not making good contact. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
