whats going on with my car??
briea
07-10-2004, 03:48 PM
i live in az and its hot! i have no idea if that would br a factor in what im about to ask. i was driving today and all of a sudden a light came on. its the oe that looks like and engine block that says PGM-FI in it. what does this mean? i stopped driving because i didnt want to rick damaging the car. whats wrong with it and do you know how much this one will cost me?
lxndr
07-13-2004, 08:14 PM
Hi Briea,
I haven't seen you post in a while!
Anyway, the PGM-FI light comes on to tell you that there is something wrong with the car, usually it is something small like an O2 sensor, but to find out what is wrong you will need to turn the car on then check the ECU (computer) under the passenger seat. The ECU will have a couple of LED lights glowing which is actually a code that helps you determine the cause of the problem.
Here is a link that will help you read these codes:
http://www.automotiveforums.com/vbulletin/showthread.php?t=236249
Unless there is a major mechanical problem, your car will continue to run because the ECU will automatically switch to a default setting if there is something wrong with one of the engine sensors.
Hope this helps!
cvcc_wagon
07-13-2004, 10:19 PM
exactly, you will just get bad gas mileage from the default setting
