RPM Gauge94GreenBeast 07-01-2004, 07:39 PM Today I was doing to normal commute when I noticed that my RPM gauge would suddenly fall to 0 and then go back up. I've seen this before in other cars but only with the MPH. Does anyone have any information on fixing it? Thanks. thunderbird muscle 07-01-2004, 08:32 PM I'm not sure, but it might possibly be a loose connection. Do you live on a dirt road or drive on one often? 4.6chickenpower 07-01-2004, 08:50 PM chek the gruond cables on the batt. it is critical that fords have a good ground, or it could be a loose connection like thunderbird muscle said 94GreenBeast 07-02-2004, 10:49 AM As a matter of fact I was driving through a construction zone that had a gravel/sand mix road, when I noticed the problem. Wow you guys are incredible. How could this have affected the RPM gauge? And now I noticed that when it gets to 2,500 RPM the needle falls and then when it goes below it pops back up. What's the deal? thunderbird muscle 07-02-2004, 05:43 PM Sounds one of the wires has been shaken loose. Like chiken power said it could be the ground, but it could be the wire on the tach there are many more. Hope you figure it out. 94GreenBeast 07-08-2004, 06:21 PM Thanks The ORIG. Dig. Oxy 07-16-2004, 04:38 AM If it's and SC check the camshaft sposition ensor. If the upshift light stays on during cranking, check the crankshaft position sensor. 94GreenBeast 07-19-2004, 08:50 PM It's not a SC. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
