Emergency brake light and ABS light ON all the time.
Google
Web AF
Slade901
07-01-2004, 10:38 AM
Emergency brake light and ABS light are ON all the time on 1994 Pontiac Grand AM 2.3L Quad 4. Emergency brake is dis-engaged properly. Vehicle moves freely and so the brakes are not dragging.
Yesterday, we were pulling into a gas station entrance and both sides of the entrance has some large bushes which is hard to see incoming or outgoing vehicle. As we were pulling into the gas station entrance, there was this vehicle pulling out and speeding up and then stopped before merging in the highway but the rear of their vehicle was blocking my way and I have to slam by brake and have to turn the vehicle to the right a little bit to avoid collision and I can hear the ABS engaged.
We parked and stopped the vehicle. After we started the vehicle later on, the Emergency brake light and ABS light are ON all the time. Turned off the engine and started it again but those two lights are still ON.
We drove the vehicle and still have a brake. After we arrived home, I turned off the vehicle and then disconnected the battery as well as the 4 ABS sensors and one in the master cylinder. Waited for 30 minutes and reconnected them back but still the Emergency brake light and ABS light are ON all the time while the engine is running.
This morning, I started the vehicle and the Emergency brake light and ABS light turned OFF. I will test the vehicle today and see if the those lights would come back ON again.
My plan is to clean the ABS wheel sensors and probably bleed the brake fluids again and hopefully it will get rid of any debris that might be circulating in the ABS component.
Any other suggestions with regards to diagnosing this ABS problem if the lights come back ON again? I know I can get a free diagnostics at Autozone to get the error code.
Thanks
Slade901
07-01-2004, 09:03 PM
Just an update:
Today, we drove the vehicle for more than 6 hours in stop and go traffic and heavy braking and so far so good the Emergency Brake light and ABS are not coming ON at this time.
snipez
07-02-2004, 01:28 AM
i had that problem, only in extreme cold though
nachyoz
07-03-2004, 05:14 PM
I had this problem, but it was because some moron at the shop didn't tighten the battery connection so it was arcing to connect. The ABS suystem draws a lot of current so the light kept turning on sometimes since it wasn't getting enough power to activate the solenoids. Just a quick check to see if they battery is connected tightly.
Slade901
07-05-2004, 12:34 AM
Thanks for the reply. I'll make sure that the battery cables connections are tight and clean.
camarols1
08-13-2004, 06:10 PM
my abs light came on the other day after pulling an e-brake turn(i'm 17) and my light stayed on it was raining out, maybe the senors got wet but the next morning i started it up and no more light. i had a bronco that did the same thing after i took it muddin and after a few dayz it turned off and never came back on. i dont think u should have a problem with that annoying light comming on again.
Google
Web AF
