93 ACCORD fuel problem
tonyoneandonly
06-28-2004, 09:16 PM
I have a 93 ACCORD with about 130 thousand miles on it. About a year
ago it wouldnt start so I put a new fuel filter on it and then it was OK.
Now its doing the same thing but when I put the new fuel filter on it
it still didnt start. I loosened the gas lines to the fuel filter and it is
getting gas, I dont have a fuel pressure gauge so I dont know if it is
getting enough pressure.
Will an electric fuel pump have low pressure ? I am thinking they work
or they dont. The car will run a few seconds with quick-start so I am
pretty sure it is a fuel problem.
Could it be something else I am missing ?
94accord-hurting!!
06-30-2004, 04:36 AM
check your fuel injectors located right in back of the head. three bolts will loosen the fuel rail which also loosens the injectors- make sure you check the o rings not ripped. whats obvious is that if a fuel pump works it has pressure. thanks for your time. 559 fresno.
tonyoneandonly
07-02-2004, 07:46 AM
I found the fuel injectors. Do I need to get new injectors, or can they
be cleaned, and how would I clean them ?
