where is the easiest place to get throught the firewall
Civic_D16Y5
06-28-2004, 01:44 AM
im wiring my friends driving lights on his 6th gen civic and where is the best/easiet place to get trough the firewall?
pictures are a plus++
lkailburn
06-28-2004, 08:55 AM
why do you need to get through the firewall if your wiring driving lights(which are what?)
just below and to the right of the battery is a half dollar sized rubber gromet. re-use the gromet by drilling a hole through it and running the wires through the grommet. it comes out just underneath/behind the glovebox
Civic_D16Y5
06-28-2004, 10:51 AM
fog lights wired to a switch
i got through the firewall, wired everything up but nothing lights up, the switch lights up but not the fog lights
lkailburn
06-28-2004, 12:02 PM
ah ok, i was thinking it might be for a fog switch.
check to make sure you got all the wires in place. and that everything is grounded
jeffseby
06-28-2004, 02:45 PM
you may have switched wires on the Relay which may have also blown the Fuse. The fog lights usually come with a very good wire diagram. look over it step by step.
Civic_D16Y5
06-28-2004, 06:17 PM
ok i wired it all right, it was jsut my crappy ground choice, choose a new place and voila there they go, and buying an voltometer is a great idea for finding ground places
jeffseby
06-28-2004, 07:57 PM
yep and some times there is rust and paint that block the flow of ground curret, well cool, we got it worked out.
lkailburn
06-28-2004, 11:37 PM
yah you usually need to sand down the area you are going to use for a ground. its better to do this just incase anyways. just so you have a really good ground connection
