wiring diagramelrob331 06-25-2004, 09:46 AM Hi friends. I recently pulled my 1991 Park avenue out of storage for about a year, I took it for a drive and realized that my battery may be bad cause sometimes it would act as if it did'nt want to start. So after getting a jumpstart, on my way home the car just shut off at the red light. I had the car towed home, charged the battery, changed the coil pack,and changed the crank sensor and still the same thing. It won't start. I put a jumper to the fuel pump and there's gas but no spark. Is there anyone in the network that has been through this problem? Please help. elrob331 littlejonny 01-24-2005, 02:41 AM amazing, I never thought I would find someone with the same car as me that has the same problems. I can't help you anymore than I can help myself. I've replaced the tps the cam and crankshaft sensors, ignition module, coil pack, prom and mine still doesn't run. The only thing I can think of next would be wiring? vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
