99 start...then stalls..
Google
Web AF
TurboMike
06-25-2004, 09:28 AM
Been working on a 99 SE with the 3400 with 98,000 miles.
Cold start is fine, but when you drive it some...stop...wait a couple minutes like going into a store or something and come out... start-stall...start-stall. Then finally it will start.
Here is what I've done so far:
First, the car came to me with ALOT of problems. It amazes me how people don't take car of thier cars.
1. I replaced the leaking intake gasket.
2. I replaced the leaking water pump.
He brought the car back with the start/stall problem.
3. His fuel gauge was reading all crazy so we replaced the fuel pump unit with a good used one (wrecked GA with 4k miles) Plus I wanted another pump to make sure that wasn't the problem.
4. I cleaned the throttle body and IAC motor. I also hooked up a scanner to make sure there weren't any codes and to "work" the IAC motor. I would raise and lower idle no problem.
5. Check fuel pressure. Holds good, don't leak off.
6. Replaced original plugs.
7. Looked for vacuum leaks, AFM hoses tight, etc. Nothing found.
Everything seems to be good, but the hot start-stall continues... I'm at my wits end. Any ideas?
The Right Formula
06-25-2004, 01:09 PM
Torque converter? My '90 did that. After even a short highway run, it would stall out when i tried to re-start.
--Jason
TurboMike
06-25-2004, 01:29 PM
no, your thinking about when you drop it in gear. This is in park
The Right Formula
06-25-2004, 01:42 PM
Happened in park too after driving for a while. The TC would just get too hot and not engage/disengage. Would need to sit off for a bit until it cooled down a bit.
Truly puzzling indeed...
--Jason
wxgal
06-25-2004, 02:49 PM
I have been having the same problems with my car (97 GA with about 93,000 miles ... 2.4 L, 4 cylinder, throttle-body injection). If you get this problem resolved, please share so I can see if that's my problem too.
gm-andy
06-25-2004, 04:25 PM
I would definetly look at the ignition module. There are known to get hot and cause a stalling condition like you described. That is why gm uses dielectric grease on them to dissapte heat and moisture. Look at the spark when it won't start. If there is no spark, you are looking at a ignition module, or possibly a crankshaft sensor.
Let me know how you make out.
Google
Web AF
