tire vibration
Google
Web AF
carborator
06-24-2004, 04:36 PM
Hello, all, first timer here. When my 1996 chevy corisca get up to speeds of 45 or higher, a vibration or woobling can be felt from the area of the right front tire. I had the brakes replaced and was told by the mechanic that he didn't feel the tire was out of balance. I am wondering if this is an alignment concern or ball bearing. The vibration can also be felt in the pedals. Any imput would be apprieciated here. I am worried about having my tire fall off on me while I am cruising done the highway, thanks
Kooterskkar
06-25-2004, 12:22 AM
Go get the tires balanced. If it keeps it up then you may want to take it to another shop (a different on than where you got the brake work done) and have them look at it. If it just started this after you got the brakes worked on it may be something that the mechanic did wrong that is causing it to shake like that. But have the tires balanced first.
carborator
06-25-2004, 08:43 AM
Thank you. I had taken it to get the brakes done because I had thought those were what was causing the vibration. I did ask the mechanic to balance them but he said he didn't feel it was necessary. The hardest thing is to find a mechanic that will listen to a woman. Bummer, but true. I will look into getting them balanced, thanks.
Google
Web AF
