2001 grandamgt will not start
Google
Web AF
iroc2476
06-23-2004, 11:19 PM
i have a 01 grand am the security light come on a couple of days ago when i was driving and the next time i tried to start is it wouldnt start up i know a code comes up and if it is cleared the will work for about a week then the same problem comes back and no one seems to know whats wrong with it so any help would be great thanks alot
JTrujillo86
06-24-2004, 02:29 AM
Your ignition lock cylinder is going out. This is a common issue with the N body GM cars (Malibu's, Alero's, G.A.'s). I used to have a Malibu and I had the same issue. Unfortunately, this repair is a bit expensive at the stealership. If they quote you over $400, run screaming to the next GM dealer and get another estimate. I have heard of some dealers trying to get $650 for this repair.
Jeremy
stenger35_68
06-24-2004, 11:54 AM
I had the same problem. Jeremy is right. If it wont start you can also put your key on the on position for about 7 to 10 minutes. When the security light goes out it will start. Hope this helps.
Tim
nova_gh
07-03-2004, 05:54 PM
i'm going to a dealership tomorrow to get an estimate on my car to get the key lock cylinder replaced cause i have the same security problem, i'll let you all know what they quoted me on.
nova_gh
07-07-2004, 07:10 PM
dealership gave me an estimate of 158.98$ for the lock cylinder and then 88$ for 1.6hrs labor. You also don't have to have the key in the ignition to reset the security light, mine does it in 10 mins without it. The security light also comes on for me while driving so i'm assuming we have the same problem.
Google
Web AF
