95 Yukon electrical trouble!?!?
rigg51
06-23-2004, 09:21 PM
Hi, I'm new here, but looked around a little and this forum seems to be really helpful. So maybe ya'll can help me...
I have a 95 Yukon (2dr. 5.7L) with electrical trouble. About a week ago my voltage gauge started fluctuating. Sitting still, driving, smooth road, bumpy road, doesn't matter just fluctuates randomly. Last Saturday the Alternator finally died. Got a new one, and a Optima yellow top, and a timing belt while i was at it...
Long story short it STILL FLUCTUATES.... died on the way home tonight. Luckily i was already on my street. Went back 5 min later and it cranked right up... I've taken all the aux lights, amps, toys, etc. off. Just alternator and BATT. Still fluctuating. ANY help would be greatly appreciated...
Thanks Again
Thanks Again
Bas_GMC
06-27-2004, 04:50 AM
Thanks Again
I would check all negative wires between the engine and chassis.
Thanks Again
rigg51
06-28-2004, 02:26 PM
I cleaned the neg batt cable with wire brush and the contact spot on the engine... Still fluctuates. I also had the starter checked and cleaned all of those terminals...
I'll see if I can find anymore neg wires.
Thanks
Thanks
rigg51
06-30-2004, 12:27 PM
STILL FLUCTUATING
so far .... batt, alternator, belt, and neg batt cable are all new... starter was tested...all fuses seem to be fine(none are blown)...
I've taken it to two diffrent shops, neither of which know, but will gladly look at it... So before I shell out some more $$$ anyone got any other ideas?
Thanks
Thanks
TweakedGM
07-13-2004, 12:22 AM
get the alternater check again you may have a brush jump.
rigg51
07-13-2004, 10:19 AM
Swapped the alternator out... Still fluctuates... any other thoughts???
lmk1975
07-18-2004, 03:48 PM
I am also having this same problem! Any help?
TweakedGM
07-18-2004, 11:31 PM
check your voltage with a hand held voltage meter. if it doesn't do it you may have a problem in your gauge.
jgary
10-20-2004, 06:38 PM
same problem here, i am getting frustrated, have tried all the same things mentioned here. what do you think about computer problem... i am running out of ideas
rigg51
10-21-2004, 04:09 PM
Well, I guess it could be a computer problem... that's about the only thing I haven't done....
I've also noticed that it's starting to ride a little rough, like it needs a tune up. I just had one not 3 months ago!!! The guy said that almost all the spark plugs were fouled...
If this is the case again... What could be causing that and would that contribute to my gauge fluctuations?
Sometimes it acts like it isn't getting enough fuel or something .... it "sputters" so i let off and then hit the pedal again and it's fine.... Some days it won't do this ... other days it does it every 10 min ... Any thoughts??? Fuel pump / filter maybe ??
jgary
11-09-2004, 11:41 PM
i ended up replacing my alternator, and it kept up. Then i found a broken ground strap from the firewall to the block, so i replaced it, still kept up. Then i ended up replacing my starter because it started to grind, and then it would just click one time and nothing, still kept up. Finally i put a new battery in it and haven't had problems since. I am suspecting that my alternator went first and fried everything else along the way.
Good luck!!!
Good luck!!!
crazy202022
11-19-2004, 05:04 PM
wouldn't you beleive I'm having the exact same problem, I guess I'm in for some headaches
crazy202022
12-25-2004, 02:04 PM
Update:
It turns out I had a bad ground, replaced the wire and the voltage has been fine since.
Still having the sputter problem though, hopefully something will be found next week.
