Converting Ur OBD Setup
bov300zx
06-23-2004, 04:36 PM
I drive a 91 with an obd0 and when my check engine light comes on I can't take it anywhere in town to see whats wrong with it. No one has the equipment to check it and I dont want to drive an hour or two to find out whats wrong. Can I convert it to an OBD1 or OBD2? If not anyway to check whats wrong myself?
Beyond Imagination
06-23-2004, 04:54 PM
check the codes yourself
Beyond Imagination
06-23-2004, 04:55 PM
1 O2A - Oxygen sensor #1
2 O2B - Oxygen sensor #2
3 MAP - manifold absolute pressure sensor
4 CKP - crank position sensor
5 MAP - manifold absolute pressure sensor
6 ECT - water temperature sensor
7 TPS - throttle position sensor
8 TDC - top dead centre sensor
9 CYP - cylinder sensor
10 IAT - intake air temperature sensor
12 EGR - exhaust gas recirculation lift valve
13 BARO - atmospheric pressure sensor
14 IAC (EACV) - idle air control valve
15 Ignition output signal
16 Fuel injectors
17 VSS - speed sensor
19 Automatic transmission lockup control valve
20 Electrical load detector
21 VTEC spool solenoid valve
22 VTEC pressure valve
23 Knock sensor
30 Automatic transmission A signal
31 Automatic transmission B signal
41 Primary oxygen sensor heater
43 Fuel supply system
45 Fuel system too rich or lean
48 LAF - lean air fuel sensor
54 CKF - crank fluctuation sensor
58 TDC sensor #2
61 Primary oxygen sensor
63 Secondary oxygen sensor
65 Secondary oxygen sensor heater
16 Fuel injectors
23 Knock sensor
58 TDC sensor #2
civickiller
06-24-2004, 01:57 AM
ok pull back your carpet on the passenger side and youll see a metal plate with a hole in it and a little light. count the number of blinks, it will blink your code, pause then start over again, so say you got a code 3, it will blink 3 times pause then start 3 over again.
so check it then cross check it with that list above
bov300zx
06-24-2004, 03:33 PM
Thanks guys
