Timingschneids714 06-21-2004, 10:27 AM I looking for someone who may be able to tell me how to time my 97 1.3l metro. I had to replace the pistons because the skirt on #2 piston let go and along with #1 piston had hair line crack where #2 let go so we decided to replace all of them to keep the engine balanced. The car only has 71,000 miles on it and it has now been rebuilt. I would appreciate any info on how to time this engine. geozukigti 06-21-2004, 11:38 AM Cylinder 1 to Top Dead Center, then line the cam gear's timing mark up with the notch in the valve cover. Install belt, tension belt. You're all set. schneids714 06-21-2004, 03:35 PM Thanks for the info. So, that is all a person needs to do to time it correctly? Wow, that isn't hard at all. geozukigti 06-21-2004, 05:05 PM Yep. It's pretty easy. Just make sure cylinder 1 is at a PERFECT TDC. If you are off by 1 tooth, you can bend all your valves. 360 degrees in a circle/40 teeth on a cam gear = 9 degrees per tooth. Then your cams turn at exactly half the speed of the crankshaft. So 1 tooth off on the cam gear=18 degrees of rotation of the crank. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
