Max Boost With stock turbo?? with gated b/caussie r33 06-19-2004, 01:11 PM Anyone know how much boost i can run on a stock R33 with exaust and intake. using a turbosmart gated controller. do i need a fuel cut defeater? Mick Trainer 06-19-2004, 10:02 PM What kind of car? Gts-t, Gtr? RazorGTR 06-19-2004, 10:15 PM Depending on the year, spec I or spec II it makes a difference. The early model spec I's had ceramic compressor wheels while the later 96 onwards had plastic, yes plastic compressor wheels! I wouldn't push a ceramic turbo over 17psi and even at that not for prolonged periods of time. The Spec II i wouldn't suggest more than 15psi for any extended period of time. Keep in mind turbo condition plays a major factor. Also you better have a very good fuel system or you'll go lean as and burn the motor up. RazorGTR 06-19-2004, 10:15 PM Assuming he's referring to an R33 GTS25t SAPrez 06-21-2004, 03:46 PM Happy B-Day Mick Trainer! vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
