What kind of coilovers are best??tegGSRrider 06-18-2004, 12:04 PM hey, Im about to get some new coilovers and I am looking at some dropzone adjustables. http://images.channeladvisor.com/Sell/SSProfiles/10055962/Images/DZcoilovers.jpg Anyone know how good or bad dropzones are? and what else would i need to get after installing new coilovers. thanks BullShifter 06-18-2004, 08:57 PM If you read or search you'll find out that Dropzones are junk. There's only one way to go with coilover sleeves, Ground Control. You will need new struts & camber kits for optimum use. Koni yellows are best suited for coilover sleeve use. Some thing to look into would be a true coilover setup, Tein basic can be found for cheap. It's just too bad there is no adjustable dampening. As always, spend the money the first time around. jcrx 06-18-2004, 10:02 PM Those are garbage, if you get a sleeve get Ground Controls, but the best is a threaded body coilover, or true coilover, where hte threads are on th shock. Save some cash and get some of those, something like the Tein, JIC, GAB, or Bilsteins. tegGSRrider 06-18-2004, 10:12 PM soslowsi 06-19-2004, 01:57 AM i have the vis v.2 sleeves on my 00 si...my stock shocks lasted for awhile..until it busted a hole in my hood..now i'm looking for some springs/shocks..in my opinion..they're a waste of money and time. SilverY2KCivic 06-19-2004, 02:52 AM http://i3.ebayimg.com/02/i/01/fa/10/b0_1.JPG jdm vis version 2 ???? ANY sleeve coilover like that (exception of Ground Control or Skunk2) is a WASTE of money, period! We all speak from experience on this, not just opinion. You pay $100 for a set of coilovers, then only expect $100 worth of a ride and handling. Do it right the first time, or waste money trying to fix something down the line weather it be blown shocks, a new hood if your stocks bust bad enough, new springs, new bushings, the list can go on... With the RIGHT setup, nothing addition $$$ wise will be needed for a LONG time. scallywag 06-21-2004, 01:06 AM yup, you will regret being cheap. It will end up costing you in the long run. If you do decide to get sleeves the best are ground control. But by the time you buy ground controls and shocks (koni yellows are very good) you had might as well just get true coilovers. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
