94 C3500 7.4L TBI Back Fires at WOTtrcrumb 06-17-2004, 04:59 PM Hi, Does anyone know what would make my 94 GMC C3500 7.4L TBI Dually continuously back fire when going from idle to WOT when in park? It also seems to have a loss of power, especially on freeway grades. Just completed tune up of plugs, wires, distributer cap, rotor, PVC, Fuel Filter, Air filter & Oil change. Truck has 116,000 miles on it and has allways been well maintained. Plugs look good at change, no oil & no noticable smoke from exhaust. PS. Truck is 100% Stock. Thanks for any and all help that you may have. TC jimss454 06-21-2004, 12:28 PM WOT in Park? Ouch!! (Why do that?). It sounds like you maintain the truck well, all the stuff you changed is good. So, does it miss while you are driving, or just revving it up? When hot, cold, or always? When you are noticing the power loss, is it during acceleration, (on-ramps), or just at increased load, (uphill grades at speed)? If the only time it misses is when flooring it in neutral or park, don't do that anymore. (Actually, there is never any reason to, and it can be harmful, especially to big-block engines!). Will try to help, need a bit more info. trcrumb 06-22-2004, 07:04 AM Hi, Thanks for the reply! Actually, It was a mechanic that did the WOT in park to check for loss of power. He suspected a clogged fuel filter. The engine never went past 2500 RPM when he punched it in park. It just kept backfiring like the engine was starving for fuel. He test drove it & said it was definitly lacking power. I replaced the fuel filter the next day & it does run better, but it still backfired when I did the same test as him, WOT in Park. Still backfired & stayed at 2500 rpm. He thought it may be some kind of rev limiter although he was not aware of GM doing that. The truck seems to lack power at all times Hot or cold when trying to accelerate entering freeway onramps & up hill grades. Truck runs great in regular traffic, it just seems to lack power under minimal load conditions. People pass me on the freeway going up hill unless I really put my foot into it, & i'm only talking 55 to 65 mph & then they still fly by me. I would think that a 454 should do better than that even with 116000 miles on it in good shape. Maybe fuel pressure? What do you think? Thanks TC jimss454 06-22-2004, 07:33 AM Hmmm. Possible fuel problem, maybe pump/pressure, or dirty injectors, but sounds more like electrical/ignition to me. Could be clogged Catalytic Converter, especially if problem set in gradually over time. Have you had the truck for a while? Did the problem start before or after the tune-up? Did it begin suddenly, or gradually? What did you set the plug gaps to? Try this: Remove air cleaner, start truck, climb up where you can see into the throttle body. (Be safe - Keep your face back as far as possible!). When you can see the spray of fuel coming out of the injectors, see if it is a nice, even spray pattern. Then put your hand on the throttle linkage and gradually increase the speed until the misfire begins. Note if the spray pattern changes, or becomes intermittent (starts/stops rapidly). Let us know what you find. -Dan. trcrumb 06-28-2004, 04:25 PM Hi, Problem has been setting in gradually over time. Problem was present before tune up. I just noticed by doing your recommended test with the engine cold that it did not backfire. Injector spray pattern looked great on both injectors. No noticable pattern change. I am wondering what could be changing after the engine heats up? That seems to be when I really notice the power loss. When the truck is cold it seems to run much better. I am thinking in your direction of electrical problem. Maybe distributer is not advancing properly after engine warms up? I noticed when i changed cap & rotor that there was alot of rusty powder inside. I even sprayed it with wd40. Do you know if there are cintrifigal (sp) weight mechanisms in these distributers that might be sticking? I was also thinking about the possibilty of plugged exhaust / cat problem as you mentioned, but does run good when the engine is cold. Maybe some heat related sensor somewhere? Thanks for all your help, what do you think? Ted pickering_c 07-02-2004, 11:30 AM It would appear that there are 3 of us with similar results...Our 454's are all losing power when loaded...Mine is a 96 with 150k miles, has the vortech tpi, 8 injectors to screw with. See post below, myself and this gentleman can't figure out anything usefull either. http://www.automotiveforums.com/vbulletin/showthread.php?t=238530 I am really leaning towards the cat's (mine has 2 from GM) but really don't want to spend the bucks to replace if no good results. Dirty injectors are always a good possibility but how do you test? I have replaced the fuel filter, plugs, wires, cap/rotor, o2 sensors (all 4). It just doesn't get any better..... trcrumb 07-06-2004, 04:28 PM I recently purchased a gm code reader to help diagnose the problem. I am getting a code 54 out of mine. Code 54 says that I am getting low voltage to the fuel pump relay, or fuel pump curcuit fault or mixture control solenoid fault. I replaced the fuel pump relay & after doing the recommended fuel pump circuit test, replaced the oil pressure switch as well. Still get code 54. Next, I am going to check fuel pressure at the TBI to see if my fuel pump is faulty. I will keep you all posted after I run the test. I hate to lower the tank & replace the pump if I don't have to & like wise with the exhaust. We'll see what the test says. At least I am narrowing it down :) pickering_c 07-06-2004, 04:38 PM An error code certainly is a start...I am going to track down a friend who has a code reader and see if mine gives the same code. I found one vendor who has cat's for the truck, $150 each, then you have to have someone install. http://www.secureperformanceorder.com/dynatechstore/powercat.cfm I am not sure which will be worse though, dropping the tank to replace the fuel pump or having a muffler shop weld in some new cats. Just for grins, have you replaced the gear oil in the rear recently? I did mine about 75k miles ago and replaced with castrol synthetic. I had someone ask and it made me wonder if the oil has broken down or something. trcrumb 07-06-2004, 04:57 PM Havn't replaced the gear oil in the rear. I just get it checked & topped off if needed at oil changes. I have been seriously thinking of replacing Cat & muffler as well, but I want to know for sure that the power problem has been nailed down first. The code reader for my truck was only $29.00 but for 96's & newer they jump to over $100.00. It will be good to resolve this problem. It has been frustrating me for quite some time now. Gotta go to work now.............. JoeBobE218 07-06-2004, 10:58 PM I highly doubt this will help but i had a 350 doin the same exact thing and it turned out to be a loose rocker arm. JoeBobE218 07-06-2004, 11:20 PM I highly doubt this will help but i had a 350 doin the same exact thing and it turned out to be a loose rocker arm. trcrumb 07-09-2004, 11:14 PM I'm curious about the loose rocker arm. Did you hear any mechanical noise before you diagnosed the problem? I assume you have Hydraulic lifters & if so, how loose was the rocker arm? & thanks for your input. PS. I ordered my fuel pressure guage from summit Racing today. Hopefully within a few days I will know if I need a new fuel pump or not :) broughy84 07-10-2004, 09:15 AM My 350 did the exact same thing as what you are discribing, it was infact a faulty fuel pump. BTW, why don't you rip the cats and the mufflers off anyway.....man a 454 w/straights sound bad ass, my falther in law has a 454 in a 82 Chevy 1/2 ton 4x4. pickering_c 07-11-2004, 02:22 PM I got a wild hair this morning and pulled all of the air filter and plumbing so that I could look at the throttle body. I was completely disgusted when I pulled the trhottlebody. The back side looked like the inside of an oil pan. Completely gunked up. I have never seen so much crud on the intake side. I removed all the sensors and cleaned with alcohol and q-tip, pulled the butterfly and cleaned the throttlebody and butterfly whit come carb cleaner. It seems to have more power and idles a lot smoother. We'll see how it behaves in the next week... trcrumb 07-21-2004, 07:46 PM Just wanted to let you all know that I am having a hard time finding a fitting that will let me splice in to the fuel line at the TBI housing. They tell me it is a special thread. I finally found one on line at http://www.tbispacers.com/gm_tbi_fuel_pressure.htm I have ordered the adapter & will keep you posted on fuel pressure reading when I get it. TC pickering_c 07-21-2004, 09:32 PM I ran mine through a decent analyzer. I have dual cat's and 4 O2 sensors. It is running extremely rich out of the back O2 sensor on the #1 side (I would have to assume that would be the drivers side). To compound the problem, the #1 side is adding extra fuel at the injector (long term fuel trim). That seems to explain why my mileage had dropped off. We are going to start swapping O2 sensors around to see if the problem follows the O2 sensor; starting with the rear ones. The bummer of the whole deal is that it is a one tyr per day project because of the heat under the cats. trcrumb 12-30-2004, 08:10 PM Well, It's been quite a while. I changed the Fuel Pump, No Difference. I had a new flowmaster exhaust put on just a few days ago, no difference. I have a new High Performance distributer & coil arriving in a few days to change the stock units out. If that still doesn't fix things, I'm taking it to a diagnostic guru I just found out about the other day. I am suspecting my torque converter or transmission sensors may not be working correctly. But at this spoint surely I don't really know. It's been a while since I updated this post, I was in the hospital a couple of times for some surgery. That slowed me down a tad :) trcrumb 01-08-2005, 08:14 PM The case has been solved! This will be my last post on this subject. :) I just finished replacing the distributer with a procomp late model HEI Hi Performance model that I found on Ebay for $85.00 New. I also replaced the coil with a MSD Hi performance coil, also from Ebay new at $30.00. The truck runs like a raped ape now! I couldn't believe how much power I had lost! There was definitly something wrong with the stock items. I am guessing that the pickup in the stock distributor was working but not at full capacity. In any event, I hope this helps some of you out there that may still be having problems with big block power issues. Thanks for all the feed back & happy Motoring :) Ted rjrhoades 01-23-2005, 01:48 AM Did anyone find a solution to this? I have been having similar problems. Fuel pump actually failed and replaced but did not cure problem. Took catalytic converter off and it helped but didn't eliminate. I think I can also detect spark knock. this usually starts to occur only when engine is good and warmed up and under moderate to heavy acceleration. It has been getting worse over time, initially noticing only when pulling a trailer. Will now do it when truck is unloaded. Local mechanic has spent lots of time. Replaced mass airflow sensor, improved idle problem but not this problem. Also noticed water temperature oscillating slowly through about 25 degrees over a cycle time of a few minutes. I'm stumped. Can't use truck for hauling. 92 Chevy c3500, 454. trcrumb 01-27-2005, 02:52 AM If you look at my last post before yours, you will see that I solved my problem by replacing my distributor and coil. If I were you, I would replace the pickup coil inside the distributor, or replace the entire distributor. The pickup coils seem to go out frequently on high milage vehicles like ours. I think that is the main culprit for loss of power. Let me know if that helps. TC rjrhoades 01-27-2005, 04:09 AM Thanks! I guess my eyes were pretty red and unseeing by the time I read this thread. I had a difficult time finding a forum that was discussing this problem. trcrumb 01-27-2005, 08:02 PM Oops, I called it a pickup coil. It is actually called an Ignition Module. My mistake, sorry. Here is a picture of what it should look like. At least on mine, a 94 it looks similar to this one here. http://files.automotiveforums.com/gallery/watermark.php?file=/503/149929D1943A.jpg Yours may look different, but I think you will get the idea. Here is an auto parts web site that you can look at for you to determine which part you need. http://www.partsamerica.com/SelectParts.asp?parttype=194&ptset=C&searchfor=Ignition+Module%2FControl+Unit&destinationpage=SelectParts%2Easp Ted RSTYCVY 01-30-2005, 02:09 PM I have a similiar problem in a non vortec 4.3. Checked all fuel, ignition, and sensors.Then for shits and giggles I did a lobe lift check on the cam and BINGO, 2 lobes on the came were worn.The valves were not opening fully. rjrhoades 01-30-2005, 05:05 PM I printed this out and gave to my mechanic. He "accidently" got shocked by the ignition wires while doing some testing and looked further. It seems the last tune up was done with Champion plugs and inferior plug wires/cap and were leaking badly, the plugs were the wrong temperature range. He has replaced those items and I am now testing to see if the problem is solved. Will see soon. Have to wait for enough snow to get off the roads to tow the trailer.... Fireplug 01-30-2005, 05:26 PM go to Snap-on web pages you will find anything and very thing you need for fuel testing jveik 03-17-2005, 08:37 AM i hear that a clogged pcv valve can cause backfiring through a carburetor i dunno if ur new ones even have that vavle tho? vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
