1999 Rodeo V6, Won't start???tdg038 06-16-2004, 06:25 PM Need a little help. I have checked spark at the plugs and it is good. Check the fuses and found the fuel pump fuse blown. Replaced fuse and still no start. I disconnected the line on the engine side of the fuel and turned the engine over, no fuel. I am guessing that means the fuel pump? What is involved in changing the fuel pump? I have a manual on the way. Thanks in advance. Gary amigo-2k 06-16-2004, 06:35 PM tdg038 06-17-2004, 01:12 PM http://www.4x4wire.com/forums/showflat.php?Cat=&Number=529309&page=0&view=collapsed&sb=5&o=1&fpart=1 Is there any way I can test the fuel pump to make sure it is bad. Also could it be the pressure regulator? What is the ECU reset? Thanks, vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
