94-95 5L Intake on 87-93 5L
WhiteCobra
06-16-2004, 05:05 PM
Was just wondering if ford improved the intakes for the 94-95 5L's i know you can get the 94-95 intake manifolds for dirt and apparently you can put them on an 87-93 mustang? Would this be worth the effort and would i see any gains?
Thanks
Thanks
zx2srdotnet
06-16-2004, 05:39 PM
i remember hearing that they are like 90% teh same motor but i cant vouch for it cuz im not a 5.0 guy but arnt teh 94 5.0 and the 93 5.0 the same motor and HP?
WhiteCobra
06-16-2004, 05:42 PM
They're both 5L but the intake is different on the 87-93 vs 94-95, you can tell by just looking at the pictures.
GTStang
06-16-2004, 07:43 PM
A 94-95 intake manifold upper will not work on an 87-93 but a 87-93 will work on a 94-95 with and elbow adapter. The stock intake for a 94-95 5.0 is no better than the one for a 87-93 5.0 .
WhiteCobra
06-16-2004, 08:57 PM
good to know
SVTcobra306
06-17-2004, 10:43 AM
Yeah, some of us SN95 folks are experimenting with eliminating the elbow and using fox-body intake manifolds. Some of them partially so that they can get Accufab TB's.
The lower is the same, except the SN95 lower intake is not drilled for the air temp sensor, as it is in the intake piping on ours.
Also, the upper intake is not set up with an EGR passage in it like the fox upper.
