2001 Silverado ElectricalRyanCSpgs 06-15-2004, 09:41 PM I recently had an intermittent electrical problem turn into a permanent problem. The airbag light, 4WD light and msg center would flash when I turned the AC or vent fan on full blast. After about 2 seconds everything returned to normal. However, the last time, the fan did not come on and I have lost the 4WD lights, digital odometer and the AC / fan - also the battery light is on permanent in the msg center. I checked all fuses and all appear intact (inside and under the hood). Anyone ever run into this problem? Thanks Ryan Jeremy-WI 06-16-2004, 07:45 AM Check your battery connections and if they're not loose or corroded have battery/alternator tested. RyanCSpgs 06-17-2004, 10:38 PM Thanks for the reply Jeremy.. the problem still exists even when the engine is not running. Are there any relays or solenoids that could cause this? RyanCSpgs 06-19-2004, 04:05 PM I found out that the alternator was only putting out .5 amps.. I replaced and now it is at a normal level. However, now my battery light flashes in the msg center (everything has been tested good including battery), all appears to be working normally. Cbeasley 07-17-2004, 08:00 AM had the same problem in 2001 silverado we had to replace both battery and alternator. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
