b18b1 crx swap HEPL!!!!
thompsonb18b1
06-15-2004, 11:21 AM
I just got a 1994 acura rs B18b1 DOHC non-vtec motor and 5 speed tranny and I want to replace my d16a6(factory) with it. I dont know much about the b18 can someone help me that has done this swap before, like give me a little bit of info about the tranny hook-up motor mount location changes anyhting and everything would help,.
and tell me if you need more info
thank
BJ THOMPSON
thank
BJ THOMPSON
Beyond Imagination
06-15-2004, 11:55 AM
best source of information is a helms manual. use a cable tranny. use the drivers side mount, the passenger side tranny mount, and the rear engine mount. buy yourself a mount kit from hcp or hasport.
drag1320neon
06-15-2004, 12:39 PM
you have to buy a mount kit, you should also get a new fuel setup, cuase your pump and regulators arent going to do it and change the ecu
Beyond Imagination
06-15-2004, 01:24 PM
uhhh ... why wouldn't the stock fuel pump and regulator work on the b18b?
drag1320neon
06-15-2004, 02:13 PM
it will work, but the fuel put out isnt the same as an integra, which wont make it run to its full potential
gs_r95
06-17-2004, 02:56 PM
you need a motor mount kit and cable tranny the full pump will work just fine with that motor and find a pr4 ecu from a da integra. ive never heard of having to change the fuel pump and i have done several swaps into crx's civics and integra's. the ecu wil take care of the fuel so no need for that. just out of curiousity what year is your car.
thompsonb18b1
06-21-2004, 07:47 AM
Its an 88 si, full mugen wide body kit, all in grey primer ....pritty
envydisqbanpapi
06-21-2004, 03:22 PM
does any noe where to find the complete b18b1 engine for my 95 honda or if u have a better egnine in mind tell me and make sure its complete plzz!!!
