92 Corolla DX Headlight Issues
Google
Web AF
chrisg000
06-14-2004, 11:40 PM
I have a 92 Corolla Sedan and the high beams will not work. The high beam indicator comes on as it should but I have no headlights. All parking and brake lamps function properly. I hit a bump with the high beams on and they went out. I then turned the low beams on then back to high and they worked. The next time I went back to low and then to high they no longer worked on high and have not since. I tried replacing the combination switch but that did not work. Also, the bulbs are fine. Does anybody have any idea what could be the problem? Are there separate relays for the high and low beams?
sboard99
12-26-2004, 07:51 PM
Hi, I have a 91 Corolla 4dr with the opposite problem. The low beams won't work but the high beams will except the indicator light does not come on when they are on. I have checked the bulbs and they are fine and all other lights work. I have also checked all the fuses (that I can find) and reset 2 relays that I have found under the dash. One of the relays is just above the main fuse box under the dash and the other one is just underneath the glove box. Have you gotten any resolve from this problem? If so, please help, I am at a loss. If not, does ANYBODY have any idea what could be the problem?
Thanks
Sandra
chrisg000
12-28-2004, 10:57 PM
My problem ended up being some bad connections on the back of the fuse box. Sorry I couldn't be of more help.
Google
Web AF
