Engine overheating
Google
Web AF
jkunzman
06-12-2004, 11:49 AM
Engine overheat at idle. I have heard that the power steering pump drives the fan and I do have a power steering fluid leak. Does the power steering pump really drive the fan? How hard is it to replace the pump?
Joe W
06-12-2004, 10:34 PM
The '93 Camry's fan is not driven by the pump,this has electric fans that are controlled by a thermostat.There is a seprate thermostat that controls coolant flow through the engine that may be the culprit.Regardless it is EXTREMELY important not to let the engine overheat.Let us know if you need more info,or are taking it to a shop.
gelcol
06-13-2004, 04:12 PM
replace the radiator to 2 ply not plastic . last time have the same problem i replace my radiator in to two row my original one got only one row radiator which got calcium deposites stucked and cause over heating.
Google
Web AF
