Keyless entry code for 2002 F-150 Lariatcraigstar72375 06-11-2004, 06:09 PM For the life of me I can't find the code for my keyless entry on my truck. The dealer is trying to gauge me by wanting to charge me $75 to get me the code. Anyone out there have any suggestions or ideas!! Help a brother out,, please....!!![/ COLOR] :eek7: landyacht 06-11-2004, 07:39 PM Don't pay the 75 bucks...that's bull. What keyless entry entry code do you need? The keypad on the door or the code to program a key fob, or the kode to have a key cut? *NOTE if you need the key cut, pay the 75 bucks, no-one else can produce them. Post an answer and i'll get back to you. The ORIG. Dig. Oxy 06-12-2004, 05:14 AM Open driver's side door. Get on one knee, or if you are a midget, climb in Look under the the dashboard, directly under the steering wheel. See that black box with a white sticker containing 5 numbers on it? I just saved you 75 Bux. YOu're welcome. :D craigstar72375 06-12-2004, 11:51 AM I need the code for the keypad on the driver side door. Thanks for the replies I will try looking under the steering column. :biggrin: landyacht 06-12-2004, 04:27 PM In that case, use the box under the dash...i was beat to it! Hope it works for you, if not, then post back! craigstar72375 06-12-2004, 08:38 PM I found it and the pin works. Thanks for all the feedback. The ORIG. Dig. Oxy 06-13-2004, 03:17 AM Maybe you should re-consider having that dealer do ANY work on your truck. They wanted 75 bux to do what you did in.. what? 15 seconds? Rip-offs.... craigstar72375 06-13-2004, 11:23 AM I've thought about that. I won't be going there anytime soon. ruralrebelracing 06-16-2004, 09:08 PM if you have any of the fords that have a universal key like the super duty trucks then i could take my key and program it to start your truck All i would need is your truck and key, and my key. The ORIG. Dig. Oxy 06-16-2004, 11:46 PM Oook. did you EVEN read the post there, rural? He didn't need a KEY. And programming an additional key is not that hard on the new transponder key equipped FORDs. landyacht 06-17-2004, 01:03 PM dealerships may charge money for stupid things, but keep in mind if you want to keep your warranty intact, they're the folks to go see. If one dealer treats you like crap, go to another. Ford doesn't call it a required maintenance schedule for no good reason! block3 06-25-2004, 10:44 AM NO you don't have to go to the dealer for keys, most locksmith have the equipment to program transponder keys. I do them much cheaper than my dealer. Security Locks vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
