'87 Civic starter motor wont workBonvivant 06-11-2004, 04:12 PM At wits end. Tried rebuilt, and now a brand new replacement starter motor..will not work. Spins just fine, will not engage. All teeth are intact, no grinding, just a whirring, shimmying sound. Battery just fine. The starter acts just fine when out of the engine. Seated properly, not a rebuilt engine, 240,000 Km on it. Any thoughts on this matter will be most appreciated...as will my wife...her car..:) tetraruby300 06-11-2004, 11:49 PM Maybe you already covered this, but I know an engine like the 300CID in my pickup you have to buy the correct starter for a manual or automatic - there is a difference. Maybe you simply have the wrong starter. Bonvivant 07-12-2004, 02:29 AM Maybe you already covered this, but I know an engine like the 300CID in my pickup you have to buy the correct starter for a manual or automatic - there is a difference. Maybe you simply have the wrong starter. Really appreciate the reply, had not thought of this. Is there a "surefire" way to identify/get the correct starter?...I do not have original...? tetraruby300 07-12-2004, 07:34 AM From the little searching I've done on the net, there is two different PNs for manual vs. automatic for my '85 Civic. I expect the same for yours. A GOOD parts store should be able to direct you to which one to buy for a manual vs. automatic starter. I don't know much about Hondas, but usually there is a difference in how far the starter gear protrudes into the bellhousing. WissNX01 07-12-2004, 04:30 PM if the starter is spinning, it might not be spinning fast enough. Could be the wrong starter, or your batt is dead. odd nimrod 07-13-2004, 02:31 AM is the soleniod new as well? if it is just spinning, then it might not be engaging which would also cause that problem. I dont know if there is a fuse for the solenoid, but that would be your best bet, or maybe the teeth on the flywheel. Hope this wasnt pointless and helped! :icon16: WissNX01 07-13-2004, 03:32 AM No fuse for the solenoid, I think new ones are one unit with the starter. Definatly check your teeth, and not the ones in your mouth. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
