Average Cost of Replacing Radiator Hose for '89 Camry
Google
Web AF
Ariaanrhod
06-09-2004, 06:45 PM
I need to have a hose replaced in my 1989 Toyota Camry, but do not want to be taken advantage of. I was wondering if anyone knew of an average or range that it would cost to have a shop repair a radiator hose. I would like to have a good idea so I know how much it should cost me.
Thank you.
yotatechie04
06-09-2004, 07:23 PM
Radiator hoses aren't really that hard to replace yourself, although if you do go to a shop, you could expect to pay anywhere from 30.00 to 50.00 depending upon labor rates. When a hose needs to be replaced, the cooling system needs to be drained, and is usually flushed, then the hose is replaced, then the system is refilled, and tested for leaks. I'm more than sure that almost any do-it-yourselfer can handle changing a radiator hose.
Daniel M. Dreifus
06-09-2004, 07:32 PM
[QUOTE=Ariaanrhod]I need to have a hose replaced in my 1989 Toyota Camry, but do not want to be taken advantage of.
The main radiator hoses are quite simple to replace. Some of the smaller heater hoses could be trickier.
Usually, the original Toyota water hoses last a very long time, so be sure you actually need one - also, if you plan on keeping the car, insist on genuine Toyota parts for replacement - quality is_much_better than aftermarket hoses.
Equally important, make sure they use Toyota brand coolant and distilled water only to protect your engine and radiator.
Could actually be better to have the dealer quote a price. Being taken advantage of in this instance might be getting the cheaper materials and compromising the longevity of your car. The cooling system is sometimes neglected, but really important. Overheating even once can quickly do extensive engine damage.
Ariaanrhod
06-09-2004, 11:38 PM
Thank you for all your help. I would have my dad do it, but I'm getting ready to move out of my dorm room and have to pack. I just wanted to get an idea because I have to take it to a shop I do not know (since I'm in a different city for school). But, thank you for the information.
Brian R.
06-10-2004, 01:08 PM
If the antifreeze is fairly new, consider draining it into a pan and reusing it. Avoid the flush in this case.
I think the cheapest money, without doing it yourself, is to get the Toyota hose and bring it to a mechanic and tell him to change the hose and reuse the antifreeze since it is still good (if you feel comfortable in saying this).
Grymloco
06-11-2004, 01:43 AM
brain, do you feel comfortable replying to people's posts? you often second guess yourself. if his antifreeze is still good.. why do try to imply it may not be?! his antifreeze is as good as mine and anyone elses!!! wtf?!
WickedNYCowboy
06-11-2004, 07:16 PM
It my be old and needed to change. Bryan can't tell if it is worth saving or not if he is not there.
Ariaanrhod
06-11-2004, 11:53 PM
Ok, well thanks for the help. (btw i'm not a he...i'm a she) and it turned out to not be a hose but the temperature gage....
Thanks for everyone's help!
Brian R.
06-11-2004, 11:54 PM
brain, Bryan - good god guys, get it together.... :)
Google
Web AF
