swap 89 engine w 97 engineHMWCRW 06-08-2004, 12:38 PM hello everyone I pulled a 302 out of my 1989 f-150 and replaced it with factory rebuilt 1997 302. I had to change firing order and fuel injector firing order to get it to run. I also changed fuel pump relay and tps, the problem is some of the air mgmt did not get re-installed and now if you get the truck to start and shut down it will not start again and there is a strong smell of gas. I am not a great mechanic but feel I've done my best and I am open to any and all suggestions or help. Sometimes it sounds like timing is off , spark plugs have fire but when taken out they are soaked in gas. hmwcrw 97chevyman 06-08-2004, 03:04 PM ok. ford did not make the 302 in 97. The last year of the 302 was 96. Make sure you do not have a 5.4 or something. HMWCRW 06-08-2004, 04:05 PM ok. ford did not make the 302 in 97. The last year of the 302 was 96. Make sure you do not have a 5.4 or something. THIS ENGINE MAY HAVE BEEN BUILT IN 1996 BUT IT WAS FOR A 1997 EXPLORER 97chevyman 06-11-2004, 10:03 AM what air management was not reinstalled? HMWCRW 06-11-2004, 02:10 PM what air management was not reinstalled? the part from the heads to the exhaust pipes and I thimk it's called the air blower vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
