my clutch is possesd
servo411
01-21-2002, 09:50 PM
ok, the last two days my car has done something weird, when i turn on the ignition, clutch pushed all the way in, it won't start. the warning lights and everything come on it just doesn't crank. it's not the starter cause it remote starts fine every time. it only does it when it's really cold out too. could the cold effect the clutch switch? if i keep trying withthe key it will finally start though. :confused:
ric
01-21-2002, 10:16 PM
try refilling your master cylinder with holy water and hope that pans out.
no seriously it sounds electrical and im not even gonna try cause i hate electrical systems with a passion...
sorry i couldnt be of more help although i would try replacing the switch or at least see if its functioning correctly like any corrosion or anything.
RickDaTuner
01-21-2002, 11:36 PM
does your car have a starter kill on the clucth is the car candain?????
if it is then you burnt out the switch a temp solution would be to manual close the switch not by presing doen on the button but by stickin a loop wire in the sensor plug to get things going again i had this problem but not sure if its the same as yours though????
