serious malfunctions
TURBOACCORD
06-05-2004, 10:30 PM
alright here is the deal...2 months ago when the turbo was installed that accord dyno was 230 hp and 190 ft.lbs...it was feeling down and out this weekend so i had a dyno done again today...134 hp and 181 ft.lbs...it was put on the wideband and all seems to be the same only exception was a/f was alittle rich...we checked the codes and it was throwing a 3...(the map code). more than likely the map box crapped on itself so i am going to go with a mechanical (missing link) rather than the electrical box that i have now....my question is this going to fix my problem? we also did a compression check and leak tests on all vaccum/boost lines....compression was 210 in all 4 cyl...and suggestions to point me in the right direction would be helpful...thanks
