88 camry runs like sh!tmidsouth 06-03-2004, 03:45 PM an 88 camry that runs real rough. the damn thing will idle but the whole damn engine shakes. it wont go over fourty and makes a horrible knocking sound ive tried everything anybody got any clue???? midsouth 06-03-2004, 03:49 PM anyone??? 1997Camry 06-03-2004, 06:55 PM Timing issue? Brian R. 06-03-2004, 07:08 PM Replace the plugs if necessary and clean the injectors. Knocking sound could be anything. Toyrolla 06-03-2004, 09:11 PM an 88 camry that runs real rough. the damn thing will idle but the whole damn engine shakes. it wont go over fourty and makes a horrible knocking sound ive tried everything anybody got any clue???? You might have a misfire and/or timing issue. I would first check each plug and wire for consistent spark. If you need the procedure for setting and adjusting timing for a Gen2 Camry, you can get it here: Gen2Camry Reference Board (http://gen2camry.proboards26.com/index.cgi?board=Maintenance&action=display&num=1073653372) Good luck... solidg 06-04-2004, 06:36 AM tuneup and timing calvic 06-04-2004, 04:04 PM I put my money on a plug wire. Either its not on the plug or its tits/up. JJ :smokin: mechy1barry 06-04-2004, 04:14 PM try when engine running(with isolated pliers)remove one spark plug lead at the time and note the difference in engine note,if when a lead is removed it makes no difference,thats where the problem lies.could be firing across 2 cyls.-head gasket/leads/cap.my moneys on head gasket. midsouth 06-04-2004, 08:00 PM thank you all RIP 06-06-2004, 08:56 PM I pulled away from a stop light 3 years ago in my 87 Camry and it took 3 miles to get up to 50 mph. It would idle but shook and bucked like hell. Took me 45 minutes to drive 20 miles. I got home and eventually found the timing was retarded 40 degrees. The timing belt had lost two teeth and slipped. It took me 3 days to change. Now it takes me 3 hours. Might be your problem. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
