1992 Astro has to sit for several hours befrore it will restartGerardjg 06-03-2004, 06:40 AM Hello and thanks in advance I have a 1992 ChevyAstro Vin Z that will not restart after long trips of 1 hour or more unless I wait at least 2 hours short rides it is fine. I am sure it is fuel pump related because when it does not start I do not hear the fuel pump when I turn the key. Any starting point for trouble shooting would be appreciated :banghead: CD Smalley 06-03-2004, 07:25 AM I believe there is a relay, located under hood, for the fuel pump. If it is failing, I think this would cause the symptons that you are seeing. Gerardjg 06-03-2004, 09:01 AM I believe there is a relay, located under hood, for the fuel pump. If it is failing, I think this would cause the symptons that you are seeing. Thanks for the reply I will change that today TBmojorisin 06-03-2004, 11:01 PM It is the fuel pump. I had the same thing happen on my 1995 astro while driving to florida from new york. the pump bearings get "warm" over a long period of time which causes the bearings to swell which causes the pump to seize up temporarily after you shut the key off. After it cools down over a period of time it works again like nothing is wrong.Then you drive again and it happens all over again. Change the pump and the problem is solved manny-man 06-04-2004, 02:02 AM Hello and thanks in advance I have a 1992 ChevyAstro Vin Z that will not restart after long trips of 1 hour or more unless I wait at least 2 hours short rides it is fine. I am sure it is fuel pump related because when it does not start I do not hear the fuel pump when I turn the key. Any starting point for trouble shooting would be appreciated :banghead: hello my name is manny and i use to own a 92 gmc safari and i had a simillar problem and my problem was the modual inside your distributor take, the distributor cap off and this modual screws on to the base of youre distributor when this modual woudl heat up it would not let my van start for a wnile untill it cooled down this will get worst as time goes on if this is youre problem well i hope this is of some help the modual was about 50.00 dollars but that was about 8 or 9 years ago hope this helps manny Gerardjg 06-04-2004, 05:55 AM hello my name is manny and i use to own a 92 gmc safari and i had a simillar problem and my problem was the modual inside your distributor take, the distributor cap off and this modual screws on to the base of youre distributor when this modual woudl heat up it would not let my van start for a wnile untill it cooled down this will get worst as time goes on if this is youre problem well i hope this is of some help the modual was about 50.00 dollars but that was about 8 or 9 years ago hope this helps manny Thanks Manny I changed the relay yesterday and I have a long trip scheduled for tomorow that will be my next step if the problem still exist vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
