auto lock/alarm
Google
Web AF
Ronke
01-20-2002, 08:03 PM
Hi. I am new to this forum and also to my '96 Tahoe which I bought (obviously) used only to discover that the doors lock and the alarm arms 10 seconds after the doors are closed. The keys only got locked inside once (so far) but it does make car washes and valet parking difficult. Although the remote entry box looks identical to the keyless entry pictures I've seen on the site, I've seen no mention of the auto lock/alarm stuff so I'm thinking it might be aftermarket. Is there any way to turn these auto functions into manual ones. Thanks.
Tireburner
02-04-2002, 12:20 PM
I would need to know who the manufacturer of the system is to be of help.
The factory system is not programmable to lock/ arm passively.
blueburbboober
08-05-2003, 01:54 PM
you have an aftermarket alarm onthere man, and someone programmed it to do that. look at the alarm and research the brand of it. the "brain" of the alarm is up under the dash, if the install on it was done correctly, it will be hard to find. after you find out what you have, go online to the manufacturers website and take a look at the manual for that alarm. it will tell you how to ovveride that stuff. if you look by your steering column, or in your fuse box, you may find some switches that dont look factory. one of them is the "valet" switch. when you move it, non of the alarm stuff will work, and it wont auto-lock on you.
if all else fails, take it to a best buy or some other trusted installer of alarms (not the dealer) and they can help you.
-Rob-
Google
Web AF
