98 Camry Rear Brake light fuseyesyes 05-27-2004, 12:43 PM I have a 98 Camry and I've been told the fuse to my rear brake light needs to be replaced. When I press on my brakes, the center brake light (back windshield) is working, the inner set of red tail lights (trunk hood) are working, but the outer set of red tail lights (body)are not. I've looked through the fuses behind the change drawer and the ones under the hood, but can not find the correct fuse to replace. Does anyone know where I could find this information? Any help would be appreciated. Thank you in advance. Daniel M. Dreifus 05-27-2004, 09:35 PM Check the wiring harness at the trunk hinge - try moving the wires while someone presses the brake pedal to see if the outer brake lights come on momentarily zutalores 05-27-2004, 09:39 PM Also get a chiltons or haynes manual and that will tell you where every fuse is in your car Joe W 05-27-2004, 09:52 PM The fact that some of the lights work makes me question that it's a fuse.If I remember right the outer (body) lights are the only brake lights besides the center one. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
