Can S13 SR20DET handle 400whp
Initial_D
05-26-2004, 01:18 PM
hi,
:eek7: can anyone tell me if the SR20DET (( RED TOP )) if it can can handle 400whp?? can I use it for daily drive with that amount of power ??
plz if I can not go for 400whp with stock internat ,can anyone tell how much I can go maximum for daily drive ??
J SPEC SilEighty
05-26-2004, 01:51 PM
Yes.
On stock internals: I wouldn't plan on it for long.
BlackBlur
05-26-2004, 07:17 PM
Ok, would it handle 300whp without many problems? Just fuel and turbo upgrades? Maybe a little extra.....on stock internals that is, would it still be reliable?
logik23
05-26-2004, 09:30 PM
I read somewhere about stock internals holding up 13PSI on stock turbo, if you're ganna make gobs of power then plan on rebuilding the engine, if you don't wanna replace internals, don't plan on lot of power.
Bryants95240sx
05-26-2004, 09:39 PM
the stock turbo on the S13 redtop is only good to about 13-14 pounds any ways after that your just choking it
AWDSR20
05-26-2004, 10:03 PM
uhhh....Front mount intercooler!!!! a must!!!
gasket + turbo and a 300HP is not out of reach?
turbo2nr
05-27-2004, 11:54 AM
umm what about fuel management, 3' turbo back, filter? fuel pump,and regulator, boost controller, safc to tune everythin.. intercooler is just to drop down the temp of air a extermely big i/c will end up making you loss hp..
:icon16: :2cents:
1
:icon16: :2cents:
1
Ben B. Draggen
05-27-2004, 12:52 PM
It definitely can. You will problably want to replace some key internal parts though. Pistons, cams, throttle bodies are minimal but ported and polished heads are definitely great horsepower builders. check out Gude's website.
Well hope i could be of some help. If you questions PM me.
stAtus
05-27-2004, 06:09 PM
mine has been making a lazy 260RWKW at 1.1bar for over two years now, for shows we wind in a little more boost 1.4bar and make close to 290rwkw all on stock SR20det bottom end. the only addition is HKS 1.2mm head gasket.
AWDSR20
05-27-2004, 06:43 PM
yeah i assumed that u have a Filter, piping done to the car. (fuel pump too) my bad!
tnx Turbo2nr for heads up!
molina_aitor
08-18-2004, 12:45 PM
there i one in england with 600Hp. I dont kow anything about the upgrades though. If you pick up june or august issue of redline (Uk mag) you can see it.
mynismo
08-18-2004, 05:28 PM
there's a 240 over in toledo ohio that dynoed 396whp (25 shot of nitrous) with completely stock internals, INCLUDING stock head gasket. he's been driving the hell out of it for a good couple years with no probs around 16psi.
he says 400whp is the absolute limit for stock engine (with much tuning). after that you need a head gasket and ras, sleeves, cams, etc. thats the main reason im looking to max out between 320-340whp. after that it takes much money to maintain and replace a blown engine with engine components.. below 350whp it is still purty streetable.
sidewayzS13
08-18-2004, 05:40 PM
im not completly sure if im correct but the stock turbo is only capable of 350 isnt it?
SR20DETpower
08-18-2004, 08:05 PM
usuallly around 266rwhp
depends if you got a lot of misc mods, maybe like pulleys, cams, etc...on top of all the usual bolt ons for stock turbo and boost controller, maybe more.
Some had their stock s13 turbo modified into a Big28 and made 333rwhp at the absolute limit, but pretty decent consider that is still the stock turbo with some mods to housing and wheels.
mynismo
08-19-2004, 11:21 AM
yea, stock turbo maxes out around there. it loses it's efficiency past 14psi.
the guy who made those dyno numbers in toledo had a t04 turbo on it and standalone sds system.
Amigo1107
08-19-2004, 08:49 PM
this thread is almost 3 months old, but it doesn't really matter, just thought i'd give a heads up...
urbabydaddy
08-20-2004, 05:47 PM
Yeah this thread is old but a little help from across the ocean!! If a daily driver with 300+ HP in a 180sx or 240sx, its quite easy. First see if you can dish out the money for an S14 turbine (big difference), 550cc injectors, and some 264 cams, and a lightly tuned ECU and there you go over 300hp. There are other roads too, like a Z32 MAF, a power fc, or e-manage, manifold (highly recommend), turbine outlet (highly recommend), remove your cat and add a straight pipe, have a metal shop weld up an exhust for you from the down pipe back. Metal Headgasketsintake manifold, and etc....
mynismo
08-20-2004, 10:12 PM
or you can go bolt ons... i have clutch/flywheel/underdrive pulleys/header/big exhaust/test pipe/ecu
should be good for about 270-280whp (14psi)... might cost a little more but its less fuel and less strain on the engine. im thinking with some 555's z32 maf, extra tuning and possibly a set of cams, i can hit 300whp on stock turbo.
maybe i just like doing things the hard way :)
