Stabilizer/sway bar
Google
Web AF
justin0717
05-25-2004, 08:48 PM
I've looked on every single website i can find, and went to a few scrap/junk yards around here, but i cannot find either a replacement or a upgrade for my sway bar, the bar is busted off at one end. At all the junk yards the only 96-98 ga's i found were in accidents and the bar was f***ed up. If anyone knows a site, or has a car they could pull it off for me, i would be greatly appreciated. Thanks alot. Oh yea my cars a 96 se.
shark2000
05-26-2004, 02:27 AM
For new upgrades try this link.
http://www.pfyc.com/store/merchant.mv?Screen=PROD&Store_Code=PFYC&Product_Code=GA4005&Product_Count=3&Category_Code=GASUSP
GTP Dad
05-26-2004, 06:49 AM
If you can't afford a new one you can check car-part.com and search for the sway bar from wrecking yards across the country. There has to be a used one out there somewhere. Although you may be ahead upgrading to one that the folks from PFYC can provide.
justin0717
05-26-2004, 08:24 AM
Thanks Mark and GTP Dad, however the link you gave me is for 99+, will fit on my 96? Ill try that other site too. Thanks.
Markgase2000
05-26-2004, 09:51 AM
Pfyc is for the newer GA's. Im finding out more and more that sunfire and cav stuff fits on GA's even on the v6's like my O2 simulator is for a sunfire/cav 97-03 , said nothing on the box about ga's but works. Also the front end frame and enginebay is same as a cav or sunfire as well as the rear seats fit in the back of GA's and vice versa only difference was ga's have 60/40 split in the rear seat backings , the clip that separates the two could easily be removed and put in a sunfire or cav so it has 60/40 folding rear seats. Perhaps look at the same year cav's and sunfires and check parts codes from gm and see if it matches for your car the same.
justin0717
05-26-2004, 10:48 AM
I'll have to try that. It makes sense though. Thanks alot.
GTP Dad
05-26-2004, 07:42 PM
I checked car-part.com and found 12 pages of sway bars. There were a large number that will fit your car. 30 mm diameter. I don't know where you are located but there should be a yard in your area that can supply you with a used one until you can find a new one if that is what you want. Prices range from $25 to $100. If you find one just e-mail them or click on the yard name and you can call them. They should ship overnight if you need it that fast. Good Luck!
justin0717
05-26-2004, 09:24 PM
Ok thanks alot. Ill just do that. I just need one for now, later on im gunna upgrade the whole suspension, but thats not til i get some more money. Thanks again.
justin0717
05-27-2004, 10:31 AM
Thanks alot for your help. I found one nearby here. At a place i didnt try, cuz i didnt know about, and im currently in the process of getting a used one for like $45. Thanks again.
achievasc92
05-27-2004, 01:37 PM
Addco make front and rear swaybars with poly bushings for n-bodies.
justin0717
05-28-2004, 11:19 AM
They dont make one for my year though, 96, the last year they make one for is 94. All the sway bars i've looked at are 1 1/8 or 1 1/4. Im not sure the inches on my car buts its 30mm, and i converted them, and neither one matches to 30. The 1 1/4 is like 31.25mm. So i think they will either be too big or too small. What do you think?
Google
Web AF
