lumina sometimes starts other time just clicks?
Google
Web AF
spycsweet73
05-23-2004, 09:46 PM
I need help with my lumina .. sometimes it will start sometimes it will just click. changed the starter but still does the same thing .. anyone have any other ideas??? we are lost on what to do..Have changed the starter 3 times with rebuilt ones but does the same thing .. Help please anyone . email me at spycsweet@yahoo.com
mjgjr72
05-23-2004, 11:17 PM
check power and ground , you might have a loose or coroded engine ground.
spycsweet73
05-24-2004, 12:01 AM
we checked all the power lines and the ground they were not coroded or loose.. Could it be a bad ignition switch???
SlamminMOfo
05-24-2004, 09:07 AM
Have you actually checked the battery's voltage?
This could be the culprit.
BCUMMINGS
08-23-2007, 04:44 PM
HI, I WANTED TO RESPOND TO YOUR POSTING ON AUTO FORUM ABOUT THE PROBLEM STARTING YOUR CHEVY LUMINA. I DON'T KNOW WHEN YOU POSTED THIS QUESTION SO THIS INFO MAY NOT BE RELEVANT ANYMORE. I HAD THE SAME PROBLEM WITH MY 1995 LUMINA AND AFTER 2 STARTERS I FINALLY FIGURED OUT THE PROBLEM. IT WAS THE KEY ITSELF. DO YOU HAVE A SMALL SECURITY CHIP ON YOUR IGNITION KEY? I ONLY HAD THE PROBLEM WHEN I USED ONE KEY BUT HAD NO PROBLEM STARTING WHEN I USED MY SPARE KEY. I HAD TO TELL THE GUYS AT THE DEALERSHIP THAT THIS MAY BE THE PROBLEM BECAUSE THEY COULD NOT FIGURE IT OUT EITHER. SO THEY MADE ME A NEW KEY ($100) AND THE STARTING PROBLEM WAS SOLVED.( AFTER SPENDING OVER $300) TO BAD I COULDN'T FIGURE IT OUT BEFORE I BROUGHT IT IN TO THE DEALER. TAKE CARE, BARRY
Be a better Globetrotter. Get better travel answers (http://us.rd.yahoo.com/evt=48254/*http://answers.yahoo.com/dir/_ylc=X3oDMTI5MGx2aThyBF9TAzIxMTU1MDAzNTIEX3MDMzk2N TQ1MTAzBHNlYwNCQUJwaWxsYXJfTklfMzYwBHNsawNQcm9kdWN 0X3F1ZXN0aW9uX3BhZ2U-?link=list&sid=396545469)from someone who knows.
Yahoo! Answers - Check it out.
var callCount = 0;function rmvScroll( msg ){ if ( ++callCount > 10 ) { msg.style.visibility = "visible"; } if ( callCount < 50 && ! imgsDone( msg ) ) { setTimeout( function() { rmvScroll( msg ); }, 200 ); return; } var delta = msg.offsetHeight - msg.clientHeight; var newWidth = 0; var newHeight = 0; delta = ( isNaN( delta )? 1 : delta + 1 ); if ( msg.scrollHeight > msg.clientHeight ) { newHeight = msg.scrollHeight + delta; } delta = msg.offsetWidth - msg.clientWidth; delta = ( isNaN( delta )? 1 : delta + 1 ); if ( msg.scrollWidth > msg.clientWidth ) { newWidth = msg.scrollWidth + delta; } msg.style.overflow = "visible"; msg.style.visibility = "visible"; if ( newWidth > 0 || newHeight > 0 ) { var ssxyzzy = document.getElementById( "ssxyzzy" ); var cssAttribs = ['#' + msg.id + '{']; if ( newWidth > 0 ) cssAttribs.push( 'width:' + newWidth + 'px;' ); if ( newHeight > 0 ) cssAttribs.push( ' height:' + newHeight + 'px;' ); cssAttribs.push( '}' ); try { ssxyzzy.sheet.deleteRule( 0 ); ssxyzzy.sheet.insertRule( cssAttribs.join(""), 0 ); } catch( e ){} }}function imgsDone( msg ) // for Firefox, we need to scan for images that haven't set their width yet{ var imgList = msg.getElementsByTagName( "IMG" ); var len = ((imgList == null)? 0 : imgList.length); for ( var i = 0; i < len; ++i ) { var theImg = imgList[i]; if ( ! theImg.complete && "undefined" != typeof theImg.naturalWidth && theImg.naturalWidth == 0 ) { return false; } } return true;}var msg = document.getElementById( "message94328181811088136018890282223302084029011" );if ( oBw.agt.match( /gecko/ ) == "gecko" ) { if ( msg && "undefined" != typeof msg ) { rmvScroll( msg ); }} else { msg.style.visibility = "visible"; } DeleteReplyForwardMove...
Previous | Next (http://us.f324.mail.yahoo.com/ym/ShowLetter?box=Sent&MsgId=943_2818181_108813_601_889_0_2822_2330_20840 29011&NEXT=1&inc=&num=&Idx=0&Search=&YY=34030&y5beta=yes&y5beta=yes&order=down&sort=date&pos=0&view=a&head=b) | Back to Messages (http://us.f324.mail.yahoo.com/ym/ShowFolder?box=Sent&YY=34030&y5beta=yes&y5beta=yes&order=down&sort=date&pos=0&view=a&head=b) Save Message Text (http://us.f324.mail.yahoo.com/ym/ShowLetter/file.txt?box=Sent&MsgId=943_2818181_108813_601_889_0_2822_2330_20840 29011&bodyPart=1&filename=file.txt&save=1&download=1&YY=34030&y5beta=yes&y5beta=yes&order=down&sort=date&pos=0&view=a&head=b) | Full Headers (http://us.f324.mail.yahoo.com/ym/ShowLetter?box=Sent&MsgId=943_2818181_108813_601_889_0_2822_2330_20840 29011&Idx=0&Search=&Nhead=f&YY=34030&y5beta=yes&y5beta=yes&order=down&sort=date&pos=0&view=a&head=b)
richtazz
08-24-2007, 10:04 PM
BCUMMINGS this post is 3 years, 3 months old. your info is valid, but please refrain from posting in outdated threads as it clogs up the boards. Please refer to the AF user guidlines on this matter. Thank you for your future cooperation. This thread will be forwarded to the appropriate moderator and closed.
Google
Web AF
