Engien Problems
Google
Web AF
Jayman05
05-20-2004, 06:02 PM
Ok i was driving and i started to over heat and i stopped and when i towed to home and when i went to start it again white smoke came out my tail and i'm wondering if my engine's gone or what.. if it's gone anyone have a engine for sale.. it's a 01 grand am SE1 V6 3.4lt.
Slade901
05-22-2004, 07:03 PM
Since you think you are going to need a new engine, I would do this instead.
Check the coolant for any sign of oil.
Check the coolant level to see if you have lost coolant and if it is low then try to add some coolant until it is at the proper level. I would just think positive at this point and probably the water pump have went out.
Check the oil dipstick for any sign of foaming (white stuff on the oil). If there is white stuff on the engine oil, then drain the old oil and put a new oil and oil filter.
Start the vehicle and let it IDLE.
Watch the tail pipe to see what color is coming out, check the temperature gauge, check the radiator fan. The radiator fan should turn on around 220 degree fahrenheit. Check the bottom vehicle or the ground for any sign of water dripping as it might be coming from the water pump.
mjgjr72
05-22-2004, 09:14 PM
if you are getting thick white smoke from exhaust you might have a bad head gasket, check to see if you are low on coolant, if you are check for external leaks if you can not see any odds are the head gasket. pull oil dipstick if oil is milky and looks like melted coffe ice cream the motor is toast if it looks ok you can replace the head gaskets.
Markgase2000
05-23-2004, 02:00 AM
If its leaking inside , id change all the gaskets to play it safe. You got warranty left? If you do your ok other wise 500-600 bucks to have new ones installed (parts and labour) if you try to do it in your back yard your gonna have fun and break stuff unless your any good with tearing apart and puttin back together Engines.
95ragtop
05-25-2004, 06:27 PM
No 1 issue with the 3.1 & 3.4.....Lower Intake Gaskets. If you deceide to change gaskets, you start with the lower intake gaskets (1 weekend if your handy with the tools). If you find the gasket was OK, you're on to the head gasket (no fun what so ever). If you do it yourself, remember to label everything and take pictures!!!! Good luck. Hopefully your still under warranty.
Jayman05
05-26-2004, 12:38 PM
I don't think i'm still under warranty because i have 120,000 miles on my car.. another thing when i ran my car it seems like there was no circulation at all in the cooling sysem because when i felt my hoses one the return to the radiader was not pressurised and the return to the engine was very presurissed?? any comments
CarSuperfreak
05-26-2004, 12:42 PM
do this then get back to us
helpme0768
05-29-2004, 05:07 PM
Just wanted to say I have a 1994 grand-am and I have white gung on my oil stick but when i took it in to have the oil changed there was no water in the oil.They told me it was condensation.
Markgase2000
05-31-2004, 09:27 AM
What is condensation if it isnt water? If a warm glass is filled with cold water doesnt the condensation build up on the outside of the glass , if that condensation isn't water then what is it?
Jayman05
06-01-2004, 12:46 PM
I CAN'T GET IT STARTED!!!!!!! i might just have to get a new block it's beend sitting for a while now and i don't want to chance it.. anyone out there selling a low mile's 01 grand am block or have any idea what kind of engine might fit my engine mounts.. let me know??
Google
Web AF
