Reverse/backup light switch
Google
Web AF
lpien57
05-19-2004, 09:53 PM
Where is the backup/reverse light switch located on 1996 VW Jetta Automatic. Lights does not work, I checkes the bulbs and fuse so I assume its the switch.
riceaterSLC
05-20-2004, 04:22 PM
did you check on the tranny? depending on the year of the car, there should be some sort of electrical connection on the tranny. if not, i would check under the gear selector (stick) in the car, maybe there is a switch back there...
boschmann
05-20-2004, 04:28 PM
I believe it's part of the multi-function transmission range switch on the upper part of the transmission near the selector cable. There is an error in my wiring diagram, but it involves a signal through the trans control module to a back up light relay (actually called the park/neutral relay). Power comes from fuse #14, check that first. The relay is in position 14, thats on the add on section above the main relay panel section, lower row second from left. Hope that helps.
Google
Web AF
