Van won't start...fuel drips out of injectors.In_Style 05-17-2004, 11:02 PM I just put a new fuel pump in, but the gas gauge was off after that and I ran it out of gas. I put gas in and drove it for about 1000 miles. Today it died the same way it did when the fuel pump died the first time. I know there is gas in it and it is pumping after the fuel filter. I pulled the line off and it shot fuel out the filter probably 12", nothing crazy for pressure but not sure how much there is supposed to be. I poured gas down the intake and it started and as long as I kept the rpms high and pumped the gas like crazy it would run but as soon and I held the throttle down it died. Any ideas??? I will be preying for responses all night so I can answere any questions you have for very quick. cadgear 05-22-2004, 01:31 AM Check for kinked/clogged fuel lines. If fuel just drips from one injector then its probably in need of cleaning or replacing. BUt if its from all of them...maybe just a blockage in the lines. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
