Howto change interior air filter on P11/W11 ?Jealousie 05-17-2004, 09:06 AM And where it is acctually? nissantech 08-22-2004, 05:19 AM the pollen filter is located behind the glovebox. to remove the filter undo all the screws (6 if i remember) and remove the glove box complete. then you can see a plastic plate (vertical) undo the screw or clip and remove the plate from the heater box. the pollen filter is behind it. pull out the filter and fit the new one. iain elkinm 10-26-2004, 04:32 PM This (http://www.g20.net/forum/showthread.php?s=&threadid=17719) should be all you need from g20.net. J..M 08-18-2005, 09:22 PM Thats why its so quiet in here ........ Everyones gone to G20 :( vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
