Need quick help
87K5Blazer
05-12-2004, 06:48 PM
I have found a 700r4 transmission out of a 84 blazer, will i be able to put it in my 87 blazer.the 84 has a 350 motor and also the same np208 transfer case. am i fine or what do i need to look for?
trannyman52
05-12-2004, 11:24 PM
as long as the trans had the same engine size it will fit !!!!
you may want to change the wiring in the trans,, so the converter
will lock properly/// the plug in the case will be different.
the valve body may look different {aux valve body in the back} but
the ports for the switches should still be there!!!
if you cannot get it to lock /// 5/16 check ball in the lu solenoid will
get the same results without the electrical BS
