turboskyr31 01-16-2002, 04:35 AM Another question for you, What kind of turbo is a tco6?? Is it a decent upgrade for an rb20det?? Any info you could give me would be appreciated! vspecv 01-16-2002, 07:38 AM never heard of a tc06,are you sure its not a td06 [TWUBLE] 01-16-2002, 05:01 PM a tc06? whats that? i kknow a td06 would be good!! haha but theres alot of work involved in fitting a td06 to an rb20det... not to mention all the other things youd need... (injectors, fuel pump, blah blah blah) NathanR32GTSt 01-17-2002, 12:58 AM So what kind of turbo would be best to put onto an RB20DET? If you want to increase the boost to something like 1.2 bar, will you need a turbo with a steel wheel - like one from a VG30 - or will a larger turbo like one off an R34 GT-T be OK? I've also heard that it doesn't really matter what kind of turbo you have as long as your intercooler is good and working well. Any ideas? Nath [TWUBLE] 01-17-2002, 03:00 PM Personally... if your not wanting to run much over 18-20psi... then y do you want a bigger turbo? thats just going to increase your lag!! Y dont you get your std turbo high flowed and put bigger compressor wheels on it :) A FUCK load cheaper too!! NathanR32GTSt 01-17-2002, 11:13 PM Does anyone out there know what kind of turbo is in a 1992 R32 GTS-t? Garret T25 or T28? And if I were to high flow it etc., how much would I be looking at in $AUS. If I want a good compromise between little lag and good enough boost i.e. 16-18psi would a turbo from an S15 be good as it is roller bearing etc. [TWUBLE] 01-20-2002, 02:45 PM If you wer to get it high flowed it would probably cost you 800-900... depending on how much you bore it out... and how much bigger wheels you go to... There is a company here in auckland that do them... but as for ausie i wouldnt know sorry phothog 01-31-2002, 03:25 AM [TWUBLE] what company ?? just curious phothog RazorGTR 01-31-2002, 04:25 AM I know Autech does them but not sure on the price. I would guess on about a $1,000 NZ The R32 GTR's came out with the small version of the T28's they are just a tad smaller than the GTiR T28 turbo. The T25's came out on the R34. [TWUBLE] 01-31-2002, 03:36 PM Originally posted by phothog [TWUBLE] what company ?? just curious phothog The best place I know of is a place called Autech Diesel & Turbo... they are on Wairau rd sort of accross from the BP (if you know where im talking about). They quoted me about $800 for something similar to a t4 conversion... so yeah go check em out! phothog 02-01-2002, 03:18 AM i trying to change your thinking the GTS-T/4 GTS25-T has a nissan copy of a T3 not a TB25/8 the GT-R's have a TB25/8 T25 turbine wheel and a T28 compressor wheel yes they are smaller than the GTiR turbos only just the GTiR turbo i mesured today was 46.5mm the standed GTS-T turbo is only something like 45mm ( dont check just chuck the cores out & keep the hsgs ) phothog vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
