door panels...94' honda accord
accordnoob
05-10-2004, 12:22 AM
hey ima noob at this stuff, but how do you remove the front passenger side door panel off of a 94' honda accord lx...any comments would be appreciated...
jamey666
05-12-2004, 07:29 PM
first, pop open the small plug in the inside door handle. there is a #2 phillips screw to remove. slide the handle back and pull out a little bit. remove the rod from handle and unplug if it has power locks. Then there is an access cover in the closing handle (for lack of a better word) pop the cover off and there is one phillips screw to remove. Next remove the outside mirror inner cover...it just pops out....easiest to pop out with window down...pull from inside the window to release the tab...not too hard...dont wanna break it. Ithink that is all of the screws...at least that i can remember off hand. Now pull on the lower part of the door panel and it should pop off then pull up. release all of your connector and wallah!! hope this helps!
accordnoob
05-13-2004, 08:07 PM
That's man...ill try that this weekend...im replacing my motor for my power window, so thanks again...
mjohn
05-18-2004, 05:20 AM
My power windows stopped working
None of the windows...as in no power...
Switch, motor? Fuse? How do I check this out?
