J30 Performance Upgrades?
Google
Web AF
NoMotive
01-15-2002, 03:44 AM
I've just acquired a J30 from my dad and was curious about modifications. Browsed for parts only to find that there are practically none (not suprised for a discontinued car) I am impressed however, with the power this car puts out still... Will 300zx aftermarket parts install well? I was thinking maybe an Intake just to start with. Brakes and new wheels might be next. The brakes squeal like a motherf*cker, plus the Bose Stereo went out :mad: Any advice would be great... Thanks
http://files.automotiveforums.com/uploads/344016deltron.jpg
jpalm
01-15-2002, 07:03 AM
I do not endorse all of these mods, but I will list some of them for you. It is expensive to mod a J30 and there are limited things that you can do. To ME, I don't feel its worth the cash for the amount of performance you get. Its up to you really, I don't want to sway you one way or the other cause I know there are some really nice moded J30's out there. Here is goes (what I can remember):
1. ECU upgrade (Jim Wolf Technology (JWT) or JET), about $500-600
2. K&N or Stillen Intake
3. Koni adjustable shocks/struts
4. Sway Bars (one guy had them custom made by Quickor in Oregon)
5. Custom Exhaust (one guy them custom made, they were Borla's)
6. Bigger tires, 16" or 17" performance tires
7. Change the gearing in the rear-end to higher gearing
These are the mods I heard of people doing or they already have. Go to the NICO site and look through some postings and well as the J30 club on Yahoo!
Best of luck!
Jeff
94 J30t, 140K miles
NoMotive
01-15-2002, 03:55 PM
Yeah... looks like there arent too many things i can do for the J30 :bloated: Oh well... i'll prolly just stick with the intake, I figures why not pump an extra few ponies since im going to be driving it a lot more. Thanks for reply.
jpalm
01-16-2002, 07:00 AM
The best thing you can do for your can is keep it in near new condition, meaning doing all the preventive maintenance when it needs done (oil, tranny flush, coolant, air filter, shocks, tires, etc). If you keep your J in great condition and tip top shape it will beat and outhandle probably 90% of the cars on the road!
Best of luck!
Jeff:cool:
i30&300zx
01-21-2002, 04:22 PM
TT it man! theres got to be a way
jpalm
01-22-2002, 07:28 AM
TT, sure, give me about 10 grand and I'll do it!
:rolleyes:
NoMotive
01-22-2002, 06:41 PM
Ha, if i were to fork out $$$ for TT, i'd get a new car instead! :eek: I wouldn't trust my motor with forced induction, the car has 145k! BTW, my J30 makes a lot of ticking and clanking sounds from the engine bay whenever she's cooling down after I turn the ignition off. Is that normal?!?!?
jpalm
02-07-2002, 12:05 PM
Yes this is normal. If it will make you feel better you can park it with the hood up after extended trips or spirited driving to allow the engine to cool better.
Keep the fluids full and clean and it will be fine. These engines are really bulletproof as long as you keep them up. Transmissions is more what I'm worried about (I have 142.5K). I recommend a FULL tranny flush (meaning not just an exchange of fluids but a pan drop and filter change as well) with Mobil 1 Synthetic and then have a tranny cooler hooked up (about $125 installed). This should help extend the life of the transmission and buy time. I know I'm on borrowed time but I'm adding a tranny cooler in March and have already done the full flush so I should get a good bit more miles until I put this tranny to bed!
Best of luck!
Jeff:sun:
NoMotive
03-17-2002, 06:10 AM
My brakes are fading, the pads need to be replaced. What are some good brands of brake pads that can handle aggressive driving? I can't anymore squealing when i brake at stoplights!
i30&300zx
03-17-2002, 10:39 AM
I mean.. you can get some standard "midas type" brakes like Monroe. Those work just fine. If you are looking for a bit more performance... check out EBC Brakes (http://www.ebc-brakes.com) for some award winning aftermarket brakes. If the J30 has brakes like the 300ZX, they are crappy to begin with. (btw only bad part of the car)
jpalm
03-19-2002, 09:01 AM
Do not use aftermarket pads, use only OEM Nissan pads! Unless you are going to spend some Jack and get Brembro or something to that effect, stick to OEM! The J30 has okay brakes for the front. Unfortunately since the car is so damn heavy it tends to warp rotors fairly quickly under hard breaking or alot of stop and go traffic. As far the the rear brakes I've been told that they are much better, better than the Q45 of the same years.
I believe a few people have had success with Porterfield's brake pads on the J. They make both pads and rotors I think. More expensive and I seriously doubt that they are THAT much better than OEM.
Jeff
kuyadabs
05-01-2002, 06:47 PM
Which koni struts fit on the J30. I've found some yellows that I've been told will fit in the front, but which will fit in the rear? Any Part Numbers?
Juhani
05-07-2002, 08:50 PM
i'm running a 1993 infiniti j30t... it's on it's second engine, and when this engine was put into it, the engine had 26k miles on it. the tranny and the rest of the car has 154k. this may sound bad but the car sounds real good, and it still runs real fast. so far, i have modified the intake, and i have cut off one of the mufflers, so now i have dual cut-off exhaust. this car is pretty damn fast on the freeway, i've taken integra's, an 80's posche 914 (not too fast), chevy trucks, a good range of things. the only place this car sucks for speed is off the line... the cars handling is still damn good for having 154k miles. and it's still plenty fast. i'm looking into putting 2 t-3 turbos on my car, and the odds of me finding 300zx TT headers is looking bleak, so, something radical is gonna have to be done... if anyone has any ideas please let me know.
i30&300zx
05-23-2002, 02:29 PM
you cant do both the 300zx headers AND turbos. The 300zx headers are only for the non turbo model (the stillen headers). Now if you mean the exhaust manifolds connecting to the 2 turbos.. than I can tell you where to get those too. The company is Pentroof. Its japanese.. search on google.
There are a few people doing a VG30DETT conversion to the j30 on twinturbo.net. Go there and ask around.
Juhani
05-30-2002, 04:29 AM
i found some TT manifolds on ebaymotors... and now, i'm placing bids on turbos 1 and 2. after that i need to get injectors... it's a slow buying process, i should be done getting the parts in a month or 2. i dont really know wheather to use one intercooler or 2.
Juhani
06-06-2002, 07:44 PM
i just purchased t3 turbo number one... number 2 is on its way to being mine. next thing on my list is 2 intercoolers and some high psi tubing, and all the oil bullshit i'm gonna need to finish this fucker. i'm almost positive its gonna need some hacking and slashing through the firewall. either way, i'll make those things fit, and it will rule. then i'm gonna work on the suspension and brakes... then i'll probably sell the car.
kuyadabs
06-11-2002, 07:57 PM
stillen headers won't fit, there isn't enough room between the wheel well and the engine block for the headers to fit..
Juhani
07-01-2002, 05:35 PM
well, now i'm just trying to get my 2nd intercooler. and we should be underway. i got a bid on it... i will win
Juhani
07-30-2002, 04:43 AM
i got all new rotors for my j30t. they are the same size as the stock ones, but they are cross drilled, and slotted. the rotors were supposed to go on a 1990 300zx, but they work GREAT on my 1993 j30t. they kick so much ass. all 4 rotors are brembo's.
ashleywat
10-03-2002, 11:19 AM
I have a 94J30 and Infiniti calls for a modified brakepad to help with the squeeling. Well it worked for about 5k miles, now the squeeling is back, but its mainly at the top when u just start driving after u pump them a few times it doesnt squeel. The modified pads are a rougher texture. good luck,,,,,,my J has 72k on it and its just about mint inside,,,,got typical door dings from idiots on the exterior,,,,,,,,
NoMotive
10-04-2002, 03:30 AM
great service :rolleyes: my car is pretty scratched up too, oh well 3M scratch remover can hide only so much, rather not waste the money on a new paint job. just had new shocks installed, it handles superb again, so im actually over the breaks squealing. might be getting new car so J30 will eventually get sold.
ashleywat
10-04-2002, 08:22 AM
If you are bold u can use 1200 sandpaper and get those not so deep scratches out then use that 3m perfect-it II compound to get the scratches out, i have done that on some scratches in not so noticeable places and it turned out great,
ratedZX
12-25-2002, 12:47 PM
the infinity j-30 is basically the same car as any 300zx that same year.i work on imports and have seen the similaritys not to mention i own a 90 300zx non turbo.the drive train motor and transmition are identical so swapping 300zx performance stuff should be a breeze.hope this helps
malcolm
03-13-2003, 01:53 PM
Throw away the VG30 and get a VH41 100more Kw and its a bolt in.
Malcolm
Google
Web AF
