from 105 to 80Zero769 04-28-2004, 09:22 AM i got an 03 cavy and i wanted to see how fast i could it so i just went i got it up to over 105 and never had a prob with the limiter or anything, but a week or so later i tried it again and around 80 i heard a whining noise(like what you hear when you run on the white line on the road) i slowed down then tried it again and it did it again i asked my friend and he said it might be the tires. does anyone here know what the noise is -Jayson- 04-28-2004, 09:24 AM how long were you driving the car at 105 mph? Zero769 04-28-2004, 09:27 AM about 1-1.5 min maybe not even that long a curve came up -Jayson- 04-28-2004, 10:02 AM you check all your tire pressures? -Jayson- 04-28-2004, 10:04 AM i had an older pair of tires and right before one of them blew out, i got what sounds like what ur getting. When i got to about 85MPH i would get a vibration from the tires that felt like those rumble strips on the highway. Zero769 04-28-2004, 10:12 AM alright ill check their knew tires but i have been doing e-turns and tray sliding cavi racer 04-28-2004, 10:27 AM alright ill check their knew tires but i have been doing e-turns and tray sliding oh man tray sliding is the best thing ever!!! :lol: but watch out for them coppers!! Zero769 04-28-2004, 08:08 PM we got a scanner and someone that knows the codes so we're cool Three_Fingers 04-28-2004, 08:49 PM Jeez! I'm surprised yer tires aren't all square by now. Hope ya don't mind buying lots of 'em. Speed won't harm a tire, usually-unless it's not rated for EXTENDED high speed driving-which means it can't dissipate the heat well enough to keep itself from separating/flying apart, etc. All that other "skillful" driving just beats the hell outta 'em-and if you have damaged them previously doing that kind of driving-high speed will finish them off quickly. Prolly separated a belt or binding on a couple of them. Zero769 04-29-2004, 09:16 AM the psi is fine their almost brand new tires. anyways im getting new tires and rims so i dont care about wear them out. i still dont know the problem -Jayson- 04-29-2004, 12:39 PM hows ur alignment? is it pulling at all? vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
